stren_g
- January 10, 2010
- ne
What are the tell tale symptoms of a bad rack and pinion? I have a 03 mounty, while driving it feels kind of unstable and I have to keep the wheel to the right a little to go straight. It also has a kind of shudder going over bumps. I was advised to check the ball joints and they are solid, there seems to be a small amount of play in the inner tie rod and I am changing the next week. The sway bar end links look good, outer tie rod ends look good, wheel bearings check out too. I did tighten up the bolts holding the rack as on was loose. Also there are no leaks that I can find. I've searched for a while here and I guess all te info is jumbling up in my head lol anything else I should look at? Thanks folks!
