Glenn Biggs
Elite Explorer<br><img src="/forums/images/stars4.
- June 18, 1999
- Aviano Air Base, Italy
- 1992 EB 4x4
Does anybody know when a radiator fan clutch is not working correctly? In the morning when I start my engine you can hear the fan engaged, but as the engine warms up it starts to disengage untill you can't hear it anymore. Is this normal? Also, should it engage when the engine temp gauge is in the middle of "NORMAL" or past it? I replaced it a few months ago with a clutch from "AUTO ZONE" just in case the old one wasn't working right. Is there a way to test these things out? Not that my engine is overheating at idle w/A/C, but when driving in the mountains it tends to go all the way past the "L" in normal, and that's without pulling a load. I'm making sure everything is running normal before I upgrade to a bigger trany cooler/w a pusher fan. Any suggestions are always welcome. Thanks.
P.S. I used the "REDLINE" coolant additive, which worked very well, but I'm stationed in Italy now and cannot order it through the USPS.
