Radio Display Issue | Ford Explorer Forums
Radio Display Issue
J-S-427
MD
98 XLT
Has anyone seen this before?
98 with in dash CD / tape and 6 CD changer in arm rest.
The display on the radio does not work.
The radio and all functions work fine, but I just can't see what I'm doing. Clock doesn't work - just ZERO display.
All I can think is to take the radio out and open it up, looking for an internal fuse.
Any ideas?
Thanks
Josh
others had had this propblem also... i think the concensus was to replace it with a higher quality aftermarked stereo.... they will ultimately cost the same
There is actually a light bulb inside the raido that has burned out. You should be able to get a replacement bulb from Raido Shack.
This is NOT the problem; it has to do with poor connections on a circuit board.
Do a search on this site, there has been a lot of discussion.
I too am a victom.
Good luck........
