98blubrd
- July 19, 2013
- Cape Coral, FL
- 2001 Explorer Sport Trac
Went to the Sport Trac this morning and smell that burnt electronic smell. Key fob was not working, car would ding like the keys were in the ignition (when they weren't) and the radio wasn't working. Did some trouble shooting and pulled the radio and it seems to be the culprit. Radio has a burnt spot and reaks like burnt electronics.
Once I unhook the radio the vehicle doesn't ding like the keys are in the ignition and the fob is working. I was just going to drive around with no radio hooked up until I order a new one. I noticed that with the radio disconnected the windows and back window will not operate. Once I hook the radio up they work (but then I get the other issues back).
Does the radio have to be hooked up to provide power to the windows? Will this all function properly once I connect an aftermarket deck? I also noticed that when I adjust the dimmer switch the relays (in the cab by the drivers right foot area) make a crackle noise. I have checked all wires and nothing seems to be damaged. Anyone have any similar problems or input?
