RCD shock and mount numbers.
corkey
Moderator Emeritus
Moderator Emeritus
Location
Sioux Narrows Canada
Elite Canuck,multiple ifs offender,, and musky maniac,, i wheel and i fish,,
99 xls,96 xl,91,08 Ranger
shooterdude199
Irmo, South Carolina
01 Sport Trac
The problem with those drawings is there are no angle dimensions, so unless you were to keep printing at different scales until you found the sweet spot, then traced them onto metal and cut by hand, it'd be VERY difficult to transfer them onto a CAD system to be laser/plasma cut.
...I have an edge coming into the shop Monday, I bet I could make up some templates for you guys that want them, and maybe even offer them with coilovers at a good price.
ya got anything off that edge yet?? and i asked my uncle about this and maybe perhaps could the brackets be machined? dont bag me if that sounds like a dumb question.
shooterdude199
01 Sport Trac
Brandon@BTF-fab
Rancho Cucamonga, CA
87 ranger
sorry I never checked back in here, the guy's edge already had a dual shock setup on it, so the original shock mounts were already cut off.
matt98sport
Elliot Lake, ON
1998 Explorer Sort, 4.0L
So did this idea completely die?? Im interested in buying the 4 brackets and the 4 gussets for the tower.. I have a stock height sport... Anybody???
corkey
Moderator Emeritus
Moderator Emeritus
Location
corkey
Moderator Emeritus
Moderator Emeritus
Location
i maybe could send down 1 side, my 96 isn't going anywhere fast, he could fab the other side off the pattern,
matt98sport
Elliot Lake, ON
I called RCD and talked to Matt, I gave him part numbers and he said the lift is discontinued but they still offer the replacement parts, and he said he had the part numbers that i gave him which were the mounts...... He probably didnt care much and was just trying to get rid of me...
Ashbourne27
Lancaster, KY
98 ford Explorer 5.0 AWD
I was looking at getting some 2.0" Fox Coilover, Emulsion, 6.5" Travel and 8" Long - King 2.5" ID Coilover Spring 750#
What sort of lift will that generate and will I need to get some for the rear end as well?
How long would my limiting straps need to be as well?
I have a 98 ford explorer 5.0 V8 AWD.
chad551 RCD lift shock mount gussets Modified 1995-2001 Explorers 3
C 5" RCD 4wd Lift discontinued Modified 1995-2001 Explorers 0
N RCD mount help Modified 1995-2001 Explorers 4
T RCD Coil question!? Modified 1995-2001 Explorers 4
I Post pics of your truck with the RCD 5" coilover lift Modified 1995-2001 Explorers 4
I RCD Lift FAQ Modified 1995-2001 Explorers 36
I RCD lift adjust down to 4 inches? And is $2k a good price? Modified 1995-2001 Explorers 10
C RCD ranger lift for 98 xlt awd Modified 1995-2001 Explorers 1
P Questions with a RCD Suspension lift??? Modified 1995-2001 Explorers 14
C RCD 5" coilover kit Modified 1995-2001 Explorers 14
V RCD coilover lift Modified 1995-2001 Explorers 6
S RCD 5" Lift Modified 1995-2001 Explorers 2
AMMO_HOOAH SuperLift or RCD Modified 1995-2001 Explorers 12
JungleSkunk Rancho Shock Question Modified 1995-2001 Explorers 19
G explorer gen 2 reservoir shock absorber exist..? Modified 1995-2001 Explorers 0
bigred4x4 Shock options Modified 1995-2001 Explorers 5
9 Monroe 58617 Monroe Load Adjust Shock Absorber Modified 1995-2001 Explorers 12
bigred4x4 shock ? Modified 1995-2001 Explorers 1
M Front shock suggestions Modified 1995-2001 Explorers 8
B Lifted shock length Modified 1995-2001 Explorers 2
A Shock absorber electrical connections Modified 1995-2001 Explorers 0
frankcal Some shock help for a lifted ex Modified 1995-2001 Explorers 5
9 Will I need shock extensions? Modified 1995-2001 Explorers 1
T Air Shock - Alternative to Coilovers Modified 1995-2001 Explorers 7
S 2" shock absorber lift? Modified 1995-2001 Explorers 17
A Question about Monroe Sensa-Trac Load Adjusting Shock Modified 1995-2001 Explorers 18
T Front End Rebuild-brakes,ball joint,shock,hub bearing,tie rods (Lots of Pictures!!) Modified 1995-2001 Explorers 2
X Stock Shock Replacement Options Modified 1995-2001 Explorers 0
W Possible shock issue? needs ideas Modified 1995-2001 Explorers 8
J Max shock size Modified 1995-2001 Explorers 5
X Front Shock Help Modified 1995-2001 Explorers 13
W dual shock????? Modified 1995-2001 Explorers 5
W Dual shock brackets? Modified 1995-2001 Explorers 8
T SOA: Don't lose your third shock & track bars!!! ***PICS*** Modified 1995-2001 Explorers 33
G Longer Shock Absorber (long reach) Modified 1995-2001 Explorers 6
N Shock Direction Modified 1995-2001 Explorers 1
K shock mounting trouble Modified 1995-2001 Explorers 5
K Shock length and performance Modified 1995-2001 Explorers 3
D Shock question...needs to to flex and be able to haul... Modified 1995-2001 Explorers 2
V what is the Rear shock length Modified 1995-2001 Explorers 1
M Shock Advice Modified 1995-2001 Explorers 1
L Wanted good replacement shock absorbers Modified 1995-2001 Explorers 1
S rearead axle shock Modified 1995-2001 Explorers 2
S Shock swap. Modified 1995-2001 Explorers 7
S Shock extension for rear? Modified 1995-2001 Explorers 0
H Shock ? Modified 1995-2001 Explorers 1
K New Shock recommendations? Modified 1995-2001 Explorers 11
W is there a double shock bolt on kit for the explorer sport 2003? Modified 1995-2001 Explorers 2
tgreene92 which shock is better? Modified 1995-2001 Explorers 2
P shock questions-01 lowered Modified 1995-2001 Explorers 3
Similar threads
