stephan325i
- October 6, 2007
- Oshkosh Wisconsin
- 1985 Bronco II, 2.8, 5spd
So i have been searching for answers to my problem/problems for a few weeks now and tried all the ideas i have found with no success.
So here is my problem that i hope i can solve soon, im sick of dealing with it. I have the same problem that i have found in other posts, when i park my truck and shut it off the battery will die within a night, no lights or any other power using accessory on. But it does not happen all the time, and there is no pattern to when it does it. Also... a year ago i replaced the alternator and the new one seemed to be keeping my voltage guage above normal, like 3/4 of the way up instead of 1/2 like it was with the old alternator. After i had the dead battery problem the first time the voltage now jumps around. At idol it is way down, when cruzing its most of the way up.
I have had the battery load tested and the alternator checked out too. Both are good according to napa and weavers.
Some possible solutions that i have found but had no success with:
1) Voltage regulator, this would make sense because of the jumping guage. But doesnt explain why some times it starts and some random times after sitting the battery drains.
2) Bad Relay (possibly fuel pump relay) This is a problem that i have had a problem tracing, it seems that by the time i get around to looking for it the problem is gone. Could use some help tracing this one.
3) Switching some wire from the alternator that goes to a selinoid to the battery instead, but to be 100% honest im not sure what is beiing said in this case. This is supposed to take care of the voltage jumping problem but who knows.
4) the last thing that i thought was a short somewhere, but i tested that extensively and didn't find anything.
Please help me if you can. i dont know if i can deal with this much more.
i appreciate any help i can get.
