You guys told me how to do it but u missed a few steps which im gonna post here
1. take door panel off this is easy u can use a door panel remover or a flat head screwdriver preaty straight foreward
2.remove stock sheet
3.(you missed this step when u told me how to do it. U have to remove the door bolts the ones connecting the dooor to the window slider are gold the rest of the bolts are black so its preaty easy to see them
4. take the slider out and shve off the 2 rivets this is easier then just trying to drill it
5. put new window in this is easy
6. slide slider back in connect on to the new window. Match up slider and put gold bolts back in this is easy to.
7. screw the first bolt in then raise the window to get acess to the second bolt and screw it in.
after this your window is in and ready to go sorry im not good with words but hopefully this helps
