They pivot upward I believe. One end is hooked into the bracket. Pull those two bolts out completely, they will also cause interference.
Before you remove the calipers, use the screwdriver to force the piston back in all of the way. Skip the C-clamp, a screwdriver is much much much faster. Good luck,
