2000co
- April 7, 2007
- Englewood, co
- '05 Mountaineer V6 AWD
I'm planning to change the rear diff fluid in my 05 Mountaineer. It's not LS diff and it's making whine noise once you hit 45 mph. I'm going to use Mobil1 75w-140 gear oil.
Is it okay to use the XL-3 friction modifier if I don't have LS? Will that help with the whine noise? Do you recommend a different friction modifier?
Should I use the black or green Permatex rtv for the drian plug or do I need to use the white thread sealant? Do I use it on both drian and fill plugs?
Do I need to add the extra pint in my rear diff?
What's the best method to open a stuck drian plug? Can I use heat?
