Apexmaster
- December 27, 2018
- kirkland
- 02 Ford explorer
How can I identify which gears I have? Here is pic of my door tag on my 02 explorer v6
Axle Code D4 = Limited Slip, 3.73 gear ratioHow can I identify which gears I have? Here is pic of my door tag on my 02 explorer v6
I am having a hard time finding a kit for all the bearings and races can you help me outAxle Code D4 = Limited Slip, 3.73 gear ratio
In the past I have purchased bearings individually as needed from a bearing supply house. Most OEM bearings are clearly marked with part numbers. Other parts like shims, crush washers, etc., are another problem, may be bought from a parts house.I am having a hard time finding a kit for all the bearings and races can you help me out
That's OK, if you know exactly which part(s) have failed, before seeing them all.Thanks, im trying to buy parts before I take apart carrier. I drive car daily and would be doing this job in 1 day.
So issue im having is the winding noise after 55mph while on the throttle. Once I let off it hoes away little bit but mostly on the gas. First I thought it was front driveshaft to front wheels because noise was under driver seat. I replaced it but it was not it. Then I checked wherl bearings found rear left hub bearing shot. I replaced and still get this noise. I will make video today and share link. Maybe someone can identify issue. I think its pinion bearingsThat's OK, if you know exactly which part(s) have failed, before seeing them all.
Pinion bearing noise ordinarily does not change in loudness with speed or throttle amount, but remains mostly constant. Noise which sounds like a whine and changes with speed and throttle amount, often going away when COASTING, is almost always GEAR NOISE resulting from bad differential support bearings, or damaged gear tooth surfaces.So issue im having is the winding noise after 55mph while on the throttle. Once I let off it hoes away little bit but mostly on the gas. First I thought it was front driveshaft to front wheels because noise was under driver seat. I replaced it but it was not it. Then I checked wherl bearings found rear left hub bearing shot. I replaced and still get this noise. I will make video today and share link. Maybe someone can identify issue. I think its pinion bearings
Or like you said open mine and inspect all bearing . Bearing are cheap.Pinion bearing noise ordinarily does not change in loudness with speed or throttle amount, but remains mostly constant. Noise which sounds like a whine and changes with speed and throttle amount, often going away when COASTING, is almost always GEAR NOISE resulting from bad differential support bearings, or damaged gear tooth surfaces.
Teeth damaged this bad would howl like hell, frighteningly!
True I found out my local yard has 2 3rd gen exploders.. just brought in 2 weeks ago. Maybe ill go grab one if still there.you can always pull another from a junk yard and swap it in while you rebuild yours its easy to do.
Ur close but kinda off, no leaf springs here. All I have to fk is unfortunately one side rear tir rod and bottom tie rod. Im just asking about size of bolts on driveline? Most video show 12 point bolt . Either 12mm or 13mmI think im not understanding. To remove the entire rear end all you have to remove is the four bolts on drive shaft think there 1/2 or 13mm been awhile. Your shocks, 8 nuts for your ubolts on leaf springs and your break lines. roll the whole assembly out from under truck. The gear ratio is not going to matter its just going to effect your mileage and how it shifts. Your going to loose some acceleration with it but its not going to hurt anything. I dont know what 3 big bolts your talking of. Less its been longer than i thought since ive taken one out haha
If I recall correctly, they are 12mm 12-point bolts. Only a 3/8-inch drive socket will fit in there, a 1/2-inch will not clear the u-joints. Socket used MUST be 12-point. I had to use an impact to loosen them, very rusty, plus I believe Ford used a form of Loctite on the threads.Ur close but kinda off, no leaf springs here. All I have to fk is unfortunately one side rear tir rod and bottom tie rod. Im just asking about size of bolts on driveline? Most video show 12 point bolt . Either 12mm or 13mm
Got it, thank God I have 12mm 12 point . What size are bolts that hold the assembly?If I recall correctly, they are 12mm 12-point bolts. Only a 3/8-inch drive socket will fit in there, a 1/2-inch will not clear the u-joints. Socket used MUST be 12-point. I had to use an impact to loosen them, very rusty, plus I believe Ford used a form of Loctite on the threads.
