Rear glass defroster only partially works | Ford Explorer Forums
mhallack
Rockland, Maine
94 XLT
Now winter is here, I need to defrost the rear hatch window. However when I do, only the top third gets defrosted. It's like the rest of the defroster in the rear window is not working. Where would I start to investigate how to fix this, if it can actually be fixed?
Unless you have aftermarket tint... Then it becomes a real PITA. I'd swap hatch windows before I messed with mine if it needed repair. Far easier.
it's kind of the same, like a metal paste that you paint on,
i have used both they both work good if you follow the directions to a t,,
