Rear hatch window removal | Ford Explorer Forums
How do I remove the rear hatch window
  • Text
    Votes: 0 0.0%
  • Video
    Votes: 0 0.0%
  • Total voters
This Forum has a great search bar.
Just type in “remove rear hatch window”, and you should find information and instructions. Should be just what you are looking for.
You are in the right place.
Good luck!
Easiest way IMO...
Open hatch glass. Remove the "C" clips on the rear glass struts, the ones to the glass itself, and pop both struts off the post that is attached to the glass. At the top of the glass you will see two "button top" bolts on the inside of the glass. Take a T-20 Torx to loosen and remove those.
Having two people to do this will be very helpful, but is possible by yourself after you see how things are attached.
Be vary careful when reinstalling those "button top" bolts. They are easily cross-threaded, and easily stripped out.
