edlord
- December 23, 2008
- Green Valley, AZ
- 94xlt
4X4 does not work
No lights came on when I try and shift to 4-H or 4-L. Lots of advice suggested the shift motor would be bad. I found a new shift motor on ebay for $70 dollars so I bought it. The connector was not the same, the origional motor has a square connector with a round inside. The new motor has a square connector with a square inside. Since the wires were the same color I cut the connector off the old motor and installed it on the new one. IT DOES NOT WORK. I have tried testing the shift control module and the light flashes. indicating that is OK. I did all of the ohm tests on the cables into the control modules and they read OK. I read all of the forum posts and am getting dizzy. I don't understand the limit switches. Can I test the old motor or the new one by removing it at putting 12 volts on the wires? If so Which ones? How do I know if the motor is good. Perhaps I should overhaul the old one and reattach the connector? This is my first post and I'm not even sure I'm doing it correctly. Thanks for any help.
