- February 8, 2003
- Sacramento, CA 95827
- 1992 XLT
Ok another question... when you did the trans... did you reuse the original wiring loom and the original shift solenoids? Or did you change it over the the hard wiring plastic later model of harness?
Do you have a pressure tester available to you?
Do you see the shift solenoids lights change when you change gears using the tester ?
