onemanonelaptop
- November 7, 2017
- Wales
- NORTH FACE AUTO 1999
Hi All,
Looking for a bit of advice. My 99 SOHC explorer has a broken cassette and has slipped timing (most likely) due to the popping/backfire sound when attempting to start.
I have a replacement engine on the way as it seems the easier route to take than fuss with installing a new timing chain set along with the possibility the valves took damage.
My question is what do you recommend i do to the replacement engine before fitting, what should i change/replace while i have it on the engine stand prior to fitting.
Thanks for your help
