Hopefully this is my last post until everything is finished. My rear axle is almost complete. I only have an AC only stick welder that is picky on rods. Luckily it turns out to work pretty well for welding on axles. I am not a skilled welder at all, but I feel confident that my welds, while ugly, are as strong as anyone. I welded inside and out of the spring perches, as well as the shock mounts. I measured as best I could on my truck, and I found that my pinion was angled up 2 degrees, so that is where I set my new perches. Oddly enough, while rangers are SOA with slightly different axles, and totally different frames, the springs are spaced apart the same as explorers. Also the diff is not centered. It is biased to the passenger side by a few inches. I put in new axle seals, and pinion seal. I stripped the axle, and will now wire brush it good. Once its painted, all I have to do is assemble the brakes. I will have it in this weekend. I have decided to delete the rear sway bar. I can post pictures if you wan't. Its just a Tiny little sway bar, and I doubt it does much at all. I tow, but I don't corner fast, and I rarely go over 60 mph.
For the front axle, I believe I am all set. I will list everything I have and let you guys look it over to make sure I am not missing anything.
-USA Standard Gear full rebuild kit
--koyo made in japan bearings
--spacers/shims
--ring gear bolts
--pinion nut
--pinion seal
--axle shaft seals (one is a strange cone shaped thing?)
--RTV and marking compound
--crush sleeve
-2 extra crush sleeves for when I fail twice
-4.11 Yukon gear ring and pinion
-(3) Moog 377 greasable U-joints (have to pull axle shafts anyway, figured I should as they are all bad)
-GMB U-bolt kit for the front driveshaft U-joint (My current straps have come loose, and the bolts are stripped)
I should have plenty of tools. I plan on borrowing a friends shop to keep warm and use his shop press. I have a bearing puller, in-lb beam torque wrench, and dial indicator. I am hoping to be doing the re-gear in 2 weeks.
