Swampy1970
- November 13, 2010
- Vacaville, CA
- 03 Sport Trac XLS
I was looking at the data from the PCM for engine rpm, ISS and OSS and wondered if there was a formula to check that the correlation between the three was correct in different gears and different engine rpm.
In 3rd gear (2 position on selector) ISS and OSS readings seem similar.
When in D - OSS always reads about 1000 to 1500 rpm higher.
What's the "good word" on this?
Maybe this info is hidden deep in the depths of the factory service manual. I obviously need to read it more as I just figured out how to read the effin' trans dipstick properly after replacing the valve body and testing half the sensors related to the trans and their wiring...
