jake122288
- May 17, 2009
- Pleasantville, iowa
- 1994 4-door xlt 4x4
SO i have two pairs of aux lights on my truck now both which run 55w h3 bulbs... one pair has a relay the other does not..here is my wiring setup...i have a roof mounted switch box which has a single 12 gauge wire running direct from the battery to a fuse block and then to my 8 switches (only two are used as of now but adding more accessories later) and then from each switch a wire runs to the accessory... the one has a relay the other doesnt as i stated.. I have about a million stock relays laying around (the ones for the fuel pump/abs/all that stuff under the hood) is there a way i can turn around and use these for my aux lights?
question number 2... with the lights that do have a relay.. i like to be able to turn my lights on for a brief period of time without the truck running or headlights on is ti wrong to put the live wire for the relay and the switched power (by toggle switch) for the relay both directly off the battery???
