- November 11, 2005
- Brooklyn, NY
- 88 89 93 95 96 Aerostars
The module is probably overheating since it doesn't make contact with the heat sink. You could either use different machine screws that are thicker (tap the hole to the next size) or use a Helicoil repair kit if you want to keep the same size screws. Sheet metal screws should work too.
