Also, if it's just the small spring inside that's broken, don't spend $50 to buy a whole new latch, just go to a proper hardware store and buy a new spring. I found one that was a very close match, but with much thicker wire (so it will never break again!) that was slightly bigger around and it still worked perfectly. So, out of pocket for this fix was $3.00.![]()
Can you give us more information about which hardware store, and possibly even a part #, that you found which worked?
Thanks!
The hardware store was a True Value. They have an assortment of springs and I just picked the one closest to what I pulled out of the latch. I have to go back to get some 2 cycle carb parts so I'll see if I can find a manufacturer and part #. It's probably readily available online if I can find that info.
- Kellman
I have a 97 ford explorer.Ive put alot of money into it since I got it a yr ago.I just found out i have alot of frame rust,but I guess it's pretty bad around where my leaf spring is on the drivers side.I am gonna have a welder look at it and see what he can do.Then spray the dark undercoating for rust after to try to cover it.I would appreciate any suggestions if anyone has one.Thank you
I had the spring issue as well. However, I noticed that if you lift the arm that goes to the handle up a bit, the problem goes away. I assume that the spring takes care of that normally. I tested my theory with a rubber band, all good. So for about $3.50 I bought a spring at Lows and installed that.
So far it works well. I had to bend the spring ends a bit and add a loop of wire but likely ACE or Dale Hardware would have had a better spring selection.
The handle has two places for the rod attachment but only one is used since it goes on both sides of the car. I attached a spring to the unused side. The other side goes to the bottom of the rod where the plastic connector is. Just make a loop of metal to go around it and hook the spring. It only took about 5 minutes to install. Just make sure to get a light duty spring.
Cheers
This!
I had the same experience. The door was more likely to unlock when I gave the key a firm flick. I could see the little broken spring in the latch. I hooked up a spring where the lock/unlock rod connects to the latch, the other end to the door sheet metal so the latch is biased "up" by the spring. $2.64 fix.
Moving the top of spring right or left had an effect on how well it worked. Make a groove when you find where you want it.
