elk93001 said:
According to the shop manual the cover has to come off.
Yep, you're right.
I replaced my class II hitch tonight with my "wrecking yard" class III.
I used the Factory Service Manual on DVD-Rom to give me the step by step instructions to do the job.
1) Remove tail lights (two screws on inside of hatch opening)
2) Remove 6 different screws from sides of bumper cover (two are in the top corner of the cover, one is at the very bottom of the bumper on the sides--look at it from laying on the ground to remove these two)
3) Remove the little plastic pins that hold the cover on (there's about 9 of them)
4) Lift up on the corners of the bumper cover, then pull the cover straight back to remove.
5) undo the pigtail for the trailer wiring.
6) Undo the 6 bolts for the hitch, slide straight back to remove.
It really wasn't that hard, but I took my time and somehow I missed removing 2 screws so it took longer. I'm very happy it's changed out now.
By the way, the Class III is in fact beefier than the class 2. The class 3 uses a run of 2" square tubing throughout the hitch (side-to-side), whereas the class 2 uses more of a C-channel that has some metal welded to the back of it in the center. If you look at them side by side, you will be able to see the difference.
