remove warrior? camber adjusters? | Ford Explorer Forums
99ex22
Wilsonville, Oregon
2000 5.0L 4x4 Eddie Bauer
Alright well I got a 3 inch BL, War153 shackles and a TT with 33's on my truck right now. I have no rubbing what so ever with the 33's. I hate the look of the shackles hanging down so im thinking about taking them off and doing a reverse torsion twist. You think I could pull it off with not too much rubbing? I dont want to do a AAL. Also does anybody know where I can get camber adjusters? Or should I not worry about my tires being at an angl like that? thanks,
-Russ
Well I took the war153 shackles off and put the stock ones back on and I dont have any rubbing in the rear. I havnt done the reverse torsion yet because I don't know how much it will rub after I lower it back down.
you mean like having an almost stock truck , ?? just the body lift and 33's,, ???
it all depends on the tire; the ACTUAL tire height, amount of tread, etc.
With my ~1/2" TT and 3" BL, my used 33" BFG ATs didn't rub at all in the front.
But when I put on my new 33" TrXus STS, I got rubbing.
Add a leaf, gives you like an inch or so of lift with nothing hanging down like the warriors do.
Alright well I finished the reverse TT and removed the war 153's. Also put my running boards back on there for the "cleaner" look. The only rubbing I had was on the running boards in the front...nothing a jig saw couldnt take care of. Im happy with the look. I think having 33" AT's saved me from rubbing problems. here is a pic!
trXus are wider ??? or taller ???
both sets were 33x12.50x15
but the BFG's were worn, so the TrXus would be taller, due to no wear of tread.
as for actual dimensions, I don't know.
Ok they are now cut. Ive been sitting out in my driveway with a hack saw for an hour cutting them. you happy?:D
