Removing Stock Fog Light from Bumper | Ford Explorer Forums
bsu4phd
Boise, ID
'00 XLS
Hello all,
The glass for my D-side stock fog light mounted in the bumber was shattered. I 'd like to take out the light to see if I can replace the glass or need to buy a whole light assembly. Preferably only the glass at a junk yard...
My question is, how do you remove the light??? I got the one screw into the bumber plastic (liner) out, and one of the two screws in the bumper. The other one is hard to reach except with a tiny ratchet wrench and tiny hands... Had anyone done this before???
In advance, thank you very much for your help!
Marc
Its very easy to remove the housing.
You just remove the 4 bolts ( 2 in the drawing and in the photograph ) and disconnect the electrical connector ( 1 in the drawing ).
I don't think the glass is a separate part. You will need to purchase the entire housing.
The passenger side is as follows:
XL2Z15200AA $87.65 $0.00 $73.63 Electrical - Chassis electrical - Fog lamps - Fog lamp assy
FOG LAMP ASSY, Explorer, w/o Limited Edition, Right 1999 - 2000
This is from Torrie at Ford Parts Network ( http://www.fordpartsnetwork.com/ )
