Reoccuring Front Bearing Issues | Ford Explorer Forums
keleko17
Louisville, KY
2007 EB and 1999 XLT
My truck is eating bearing. How can I determine if the spindle is the problem, or if I am just an idiot?
If the spindle is bad, what do I look for, for replacement? I have tried looking on Rockauto.com and searched for axle, spindle, etc. I can't seem to find the replacement part.
I replaced my drivers side back bearings in September 2013, and had to do it again today. I think I might have snugged them down a little tight trying to get the castle nut lined up. I set them to 20 ft. lbs., then backed it off 1/2 a turn, then just tightened it up basically, but the nut didn't line up, so I had to give it a little more. I have driven about 10 miles on them, can I back it off without problems, or are they toasted again?
Here is the spindle:
If the cotter pin won't line up, better to back off than tighten the extra 5 degrees.
Did you replace the cup inside the disc as well as the cone bearing? Important that they both get replaced.
Bill
I replaced the races last time, I decided to roll the dice this time. But I did do the inner and outer..
