Its a very simple task.
First disconnect your negative battery terminal
Remove air intake tube for easier access
Unplug the wire harness to the voltage regulator
Loosen the serpentine belt and remove from the alternator pulley
Remove the 3 x 13mm bolts
Remove the alternator from truck
Good luck ....
