Replaced bulb but turn signal still inop | Ford Explorer Forums
azag
Tucson, AZ
'94 XLT
Hello all,
I've got a problem with my '94 XLT front right turn signal. When I set the turn signal for a right turn the front signal light does not come on and the rear signal comes on steady (does not flash). I replaced the front turn signal light, but the problem is the same. The left turn signals work fine. I checked the fuses and they appear fine as well.
Any thoughts?
Thanks,
AZAg
check the output from the multi function switch. Try putting the hazzards on and off a few times.
Check your flasher. Cheap and easy to fix.
Thanks
Thanks for the responses. Now that I've gotten around to reading the "read this before posting" message, I realize I should have posted in the general section. Thanks again and I'll search the general section for multifunction switch and flasher.
