35Remmy
- March 4, 2008
- Binghamton NY, Hazleton PA, Northern NJ
- '88,'99 Ranger, '00 EX
OK guys...I'm sick of this!!! After ALLLL of that work:
My idle is rough and when I take off the motor sounds lumpy.
I can even hear it in the fluctuation of noise from my power steering pump.
When I drop into OD or 4th with OD off, I get a BAD stumble or shudder.
If I floor it, motor is FINE.
I disconnected the IAC (thinking I may have damaged it when cleaning the inside of the plenum) and the idle goes down like it should. Reconnect the IAC and idle rises as normal.
ANY ideas??? No I didn't check my plugs b/c I didn't think they could foul from anything I did. I'm going back out to double-check vacuum lines.
Maybe the RTV I had to use on the back and front of the block to fill the void of the 2 piece gaskets didn't seal correctly? I'm gonna take some carb cleaner and shoot it into that spot.
See, I was all excited about this job and now I have a headache. That's my luck, though.
