Replacement Front D-shaft | Page 2 | Ford Explorer Forums
The 9622 is a 4 bolt flange. the 9450 is 22 3/4" tube length only, weld to weld
Dan Spang
Cardone Technical Services Dept.
ASE Master Certified
Sent: Thursday, September 28, 2006 11:48 AM
To: Dan Spang
Subject: Re: RE: 1997 Explorer Front D-shaft, Part# 65-9622
Thanks for the speedy response Dan.
One question I have; I do have the 5.0L, and where I've seen the 65-9622 it says it's a 27 13/16" shaft. That's the length of my driveshaft. What is the difference between the 65-9622 and 65-9450?
just curious if anybody has figured out a part# for a front d-shaft with double-cardan and 6-bolt circular flange.
The one part # I got from Cardone is a OEM-style cv-joint.
Waiting on a reply to see if they make one with a double-cardan.
well Cardone makes no replacement for the OEM cv-joint style d-shaft.
