Erika
- August 29, 2008
- Orange, CA
- 2001 XLS 2WD
Hey there, I'm new here and have had some overheating/high idle problems with my 2001 V6 explorer. Have been reading past threads on here for hours... Problem is very intermittent. Will run perfect for awhile, then, maybe after 30-40 minutes of stop and go city driving the idle will come up, from normal around 500 rpm to around 1000. Once that happens, the temp starts rising. Slowly.. but it will creep up very steadily. I don't think this is a faulty sensor because when stopped, I can hear coolant bubbling and everything just "feels hot." If I go from drive to park, the idle jumps up even higher. Happens with or without a/c on. Turning on heater doesn't seem to help. This doesn't happen every day, rather, on a weekly basis. I can't figure out what triggers it, if its mileage, or time or what. Doesn't do it cold, only at normal op. I've replaced the thermostat already. I've squeezed hoses, they're good. I've checked for vacuum leaks and can't find any obvious ones. Water pump is not leaking, no wobble at the fan. I have the idle air control valve sitting next to me, its gonna get cleaned up, but I don't think that's it either. One culprit may be the fan clutch, as when its cold, it does not turn freely like from what I've read, it should. I read somewhere that if you replace the fan clutch, the water pump should be replaced as well since they both utilize the same shaft and when one fails they should both be replaced. What's your opinion on this? Also, is there anything else I should check out before replacing the fan clutch and/or water pump? Car has 218,000 miles and has been really good to me up until now. Sorry this is so wordy..
