ok guys-
I figured out why my driver's side door lock isn't working on my 2000 Mountaineer. The actuator works fine- moves up/down, etc. However, the rivet that attaches the body of the actuator to the door itself has broken off. So when I fire the actuator, the entire thing moves up/down, instead of the arm/lock moving up/down.
The head of the rivet is sheered off. There's a piece of it still in the actuator that I can't see to get out. The entire actuator is in behind the sheet metal of the door, wedged between the door frame and the track for the glass window. There's some play in it- but not much. I can't turn the actuator to face the holes so I can have a better go at it. I'm about to burn the truck down, I'm soo frustrated.
So- here's my questions.
1) How can I get the shaft of the rivet out of the body of the actuator?
2) I've never used a rivet gun before- assuming I can fix #1 above, how do I re-rivet this back to the door to hold it in place? I'd have to hold the body of the actuator with one hand, and try to rivet with the other. I don't even know how a rivet gun works- any insights before I beat the hell out of this door?
Thanks!
Thanks!
