- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
Ahaha you're right, I have no idea why I said that.
Psst, this is still an AWD TC, no 4WD low etc.
Okay great, you have the early 1996 front shaft. That one has no CV joint, that is a double cardon joint at the rear of the shaft. Those are easy to service, there is just three u-joints to deal with.
The big thing is that you know if it's bad easily. So then the AWD is surely the only thing left besides the front carrier itself.
Okay. This is good news. It has to be a lot cheaper to replace 3 u-joints than a rebuilt shaft with the CV joint. I do have a question about the ball and socket thing I see in there. What do I do with that? And what do you mean by the front carrier? Thanks for following this thread.
nj...I'll fill ya in on how my transfer case sounds. If I take off from a standstill under hard acceleration I get an EXTREMELY loud thump...sometimes a few thuds in a row. If I take off the front driveshaft the noise is gone. I have changed the driveshaft and still get the thump. I would say if you are getting a clicking try the driveshaft first. Mine's definitely the case (I hope ) and I liken the noise to a bike with a loose chain. Remember when you would pedal really hard and the chain would slip? Magnify that by 100)
Okay this helps, and now that CDW6212R has informed me that mine is a double cardon joint and relativly cheap to eliminate as the source of the noise, I'm going to try that today. But does a transfer case make noise when the chain is stretched, but not to the point of slipping?
I have never done the joints of one of those. How is it different from any other u-joints to change?
"...I do have a question about the ball and socket thing I see in there. What do I do with that?..."
Can you post a picture of that, it doesn't sound the way I would describe a double cardon joint.
That "ball and socket" is the central portion of a double-cardan joint.
MountaineerGreen's driveshaft thread:
http://www.explorerforum.com/forums/showthread.php?t=185232
Does anyone have a picture of the chain that goes in this TC? I would like to see one if anyone can help.
Scroll down a ways. It's a 4405 but this should be pretty close.
http://www.explorerforum.com/forums/showthread.php?t=182071
