Reprogram Engine cooling fans to operate on lower temps
Black Eyed
Location
Saudi Arabia
Riyadh
Explorer 2015 base model
i'm having an issue with my Ford Explorer 2015
i'm living in hot area and my engine cooling fans won't operate on high speed until the outside temp reach 44c - 111F
at the day i can hear the cooling fans running on high temp but at the night no which effect my A/C performance.
Any way to reprogram the fans using forscan ?
Regards.
omar302
Doha
2016 Ford Edge Sport
It is probably an Engine PCM tuning thing, not in the As-built data. Also, do you mean that your A/C is ok in day time when the fans run at high speed? Because in night time, the A/C should be ok even with reduced fan speed. Your Expolrer is a 2015, so should still be under warranty, maybe take it to your dealer for service. I know from 2 Explorers (2012 & 2013) in Qatar both have very good A/C at the night. The problem should be in the day time when it is very hot & parked under the sun.
thefranchise713
Buffalo, NY
'18 Toyota Prius Prime
Unlikely with the ABD in the PCM, which is what FORScan can manipulate.
As omar stated, your better bet is to return to your dealer and see if there is an updated calibration for your PCM or other concern.
I wonder if it's also really an HVAC concern, as the sunload sensor (not sure if your base model has one) is detecting a lower level of light hitting the cabin at night, and then somewhat 'derating' the A/C for efficiency reasons. On that thought, see if there is an HVAC calibration update as well.
Black Eyed
Location
Saudi Arabia
Riyadh
My A/C not ok even in Day until the outside temp reach around 111F so the high speed engine fans kick in.
I'm wondering, i see other explorers in the street even at night, i can hear their engine fans are running on high speed while mine is not.
omar302
Doha
Then you have a problem, check with the dealer since it is under warranty.
Black Eyed
Location
Saudi Arabia
Riyadh
This is what i'm thinking, i will go to the dealer. even if the A/C is ok i want them to check the engine fans.
is it possible that because i changed my front Grill to Police version which has more vent?
thefranchise713
Buffalo, NY
I doubt the grille will make much of a difference. All of the grille designs are fairly open, up to and until the point where the grille shutters close when the extra flow isn't necessary and just serves to create drag.
omar302
Doha
My understanding is that there were no grille shutters for 2015 models, so this should not affect your situation. But, maybe during the grille change some connector was not re-installed correctly. I'd suggest you go through all the connectors. Makes sure the fan connectors are good & the outside temperature is also connected. Also, did you check if both fans are running or only one?
peterk9
Staff member
Moderator
Ottawa, Ontario area
2020 Aviator Reserve
Callsign
VE3
That is correct. Active Grille Shutters were introduced on the 2016+ Explorers but not on all of them.
Black Eyed
Location
Saudi Arabia
Riyadh
I did install the grill by my self, there is no connectors behind the grill or any way near the grill. both fans are running ok and also outside temp connector is working fine.
i can hear the fans running on high only of the weather was very hot. which prove there is nothing wrong with the connectors or the fans.
omar302
Doha
Did the issue only happen after the grille was installed? If yes, try to return to stock & see. If the issue was there from before, then check with the dealer. Sorry I am out of other ideas.
Note: on the Edge/MKX, the fans run on full speed at about 34-36C, which in my opinion, is a little low!
Black Eyed
Location
Saudi Arabia
Riyadh
I can't remember because i did install it since long time ago, but i will install the stock one then i will see.
thank you for your help.
R Nitrous oxide on a 3.5 N/A engine ? Modified 2011- 2019 Explorers - Tuning & Mods 1
T Will basic mods from the 3.5L fit on the 3.7L engine? Modified 2011- 2019 Explorers - Tuning & Mods 2
J Aftermarket Exhaust For N/A Engine Modified 2011- 2019 Explorers - Tuning & Mods 3
G Coyote engine swap Modified 2011- 2019 Explorers - Tuning & Mods 6
X Time to change engine air filter Modified 2011- 2019 Explorers - Tuning & Mods 11
SurrealOne Odd engine power RPM surge problem Modified 2011- 2019 Explorers - Tuning & Mods 10
G (SOLVED)Trouble In Tuned Paradise (blinking check engine light) Modified 2011- 2019 Explorers - Tuning & Mods 25
X Ford Explorer 2.0 Ecoboost Engine Modified 2011- 2019 Explorers - Tuning & Mods 6
E 2013 Ford Explorer Sport - Engine Issue Modified 2011- 2019 Explorers - Tuning & Mods 2
D Engine Swap Modified 2011- 2019 Explorers - Tuning & Mods 1
S Engine Sound and Throttle Response Modified 2011- 2019 Explorers - Tuning & Mods 5
L EcoBoost Engine Solution Modified 2011- 2019 Explorers - Tuning & Mods 0
L Livernois 3.5L Ecoboost Off-Road Baja Race Engine Modified 2011- 2019 Explorers - Tuning & Mods 1
C What is this engine part? Modified 2011- 2019 Explorers - Tuning & Mods 8
C Replacment PCM/Engine/Vehicle Main Computer Modified 2011- 2019 Explorers - Tuning & Mods 3
L Livernois Motorsports 3.5 Ecoboost engine build with upgraded rods and pistons Modified 2011- 2019 Explorers - Tuning & Mods 9
M MODS for 2012 explorer? normal 3.5 engine Modified 2011- 2019 Explorers - Tuning & Mods 2
S '07 Ford Explorer 4.0-V6 Engine Swap with 3.5-V6 Modified 2011- 2019 Explorers - Tuning & Mods 8
R No engine bay lighting!!! Modified 2011- 2019 Explorers - Tuning & Mods 10
