Resolving no start issue on 99 EB | Ford Explorer Forums
slayne
Wichita, KS
99 EB
This is my first post but I've used this site previously to research issues and solutions that have come up on my 99 EB. The problem I had was fixed using the wealth of experience expressed in the various forums. My problem was a no start; engine turns over but wouldn't start. It has 99K on it and since I'm the second owner I don't know how well maintenance was kept. I researched all the posts regarding no starts, fuel pump, and fuel filter. I did the common steps to isolate the problem and determined I might have a dead fuel pump based on the symptoms. I could never hear the fuel pump prime so I was 90% sure it was the pump but I wanted to replace the fuel filter and observe if fuel was pumping from the open line. If I had to replace the pump I'd need to replace the filter anyway. Fuel filter came off with a little resistance and when my wife hit the starter I had a nice stream of fuel flowing from the line. So the prognosis was a clogged fuel filter. I put the new filter on and it started and ran after a couple of tries. I dicsonnected the battery to reset the computer and it's been good so far. So I'd suggest this as a simple check before you decide to replace the pump. This site really helped direct me to find the root cause pf my problem before spending $200 - $600 dollars with the local Ford dealers.
