dubbio
- December 2, 2015
- Ohio
- 2002 Explorer XLS
Hello! again. my name is steve, im from ohio. i'm back on the forum again after a few years without an explorer, sad boring years.
this time around i managed to find an '02 XLS with a manual trans, its only RWD but has the D4 axle code (3.55 LS?). it was a steal for $400. only kicker so far seems to be the clutch is fried, as a bonus it turns out no one ever made replacement parts, or very few. The 4 door featured the m5odr1-hd, but with a 26 spline 1 1/8" input shaft, and its a dual mass flywheel setup so the clutch disc is unsprung.
ill likely be asking a ton of questions regarding clutches from 4.0l motors, measurements and the like. probly my biggest question is can i use a 23 spline input shaft? if thats a go then im likely to convert to the readily available clutch setup and be on the road for another $300 which gets me all-in under $1k
