Reverse Light Wiring Question.... | Ford Explorer Forums
CarFreak146
Shawnee, Kansas
'94 Explorer XLT
I'm pretty good at wiring, except custom stuff like this, envolving relays, so here it goes::
I'm gonna put KC Hilites Reverse Light Kit in my rear bumper when I get it, and I wanna wire it to a center off, two position on switch, I just don't know how to do it.
Left Position = Works with Facorty reverse light circuit
Center Off = Won't work with anything (NO Power what so ever)
Right Position = Can manually be switched on.
Now, I know that however I do this, I'll have to tap into the factory reverse light circuit, and run a power wire seperately for the two ON positions.... but how do I go about wiring it up to a relay and the actual switch?? A diagram would be great.
--Ryan
1) reverse tap > switch on1> relay signal
2) power > switch on2> relay signal
Both signal wires can be run into the same relay prong. The rest of the relay wiring will be normal.
thanks alec, but I'm dumb with Relays, I can never remember which numbers equal which, and what type would I need? a DPDT??
--Ryan
Just a normal relay will work.
30 is power
85 is ground
86 is signal
87 is load
alright, thanks a TON Alec.
--Ryan
