2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
Listed below are my revised SOHC maintenance intervals based on my 2000 Ford Explorer Owner's Manual, my modifications, my driving habits and my personal preference. I am retired and will probably drive my Sport less than 5,000 miles per year. The engine oil flows thru a front mounted cooler and the radiator cooler. The transmission fluid flows thru two front mounted coolers. I don't drive off road and I only tow a very small utility trailer.
3,000 miles/6 months clean:
MAF sensor
IAC valve
5,000 miles/1 year replace:
engine remote full flow oil filter
15,000 miles/3 years replace:
engine remote bypass oil filter
engine synthetic oil
transmission remote full flow oil filter
30,000 miles/5 years replace:
air filter
fuel filter
engine coolant
60,000 miles/5 years replace:
spark plugs
75,000 miles/5 years replace:
automatic transmission fluid
PCV valve
camshaft front & rear upper chain tensioner
150,000 miles/10 years replace:
rear axle synthetic lubricant
serpentine belt
radiator cooling fan
lower intake manifold top & bottom gaskets
MAF sensor
IAC valve
air filter
fuel filter
engine coolant
spark plugs
PCV valve
serpentine belt
