right rear turn signal doesn't work | Ford Explorer Forums
gwg420
2002 ford ranger
Greetings,
My right rear turn signal has quit working. I have power to the right rear socket for the turn signal. took the working bulb/plug from left side of truck, plugged it into the right side turn/brake/tail light. It did not work. Put it back to the left side and it worked. Tried socket/bulb from right side on the left side and it worked fine, put it back to right side it doesn't work. any ideas ???
gwg420
Do you have four ways?
If you do, but only one side for the turns, the switch is bad.
