Rims | Ford Explorer Forums
Rims
  • Thread starter Thread starter tech1
  • Start date Start date
If you take off the wheel and look at the back side of the centre, you will find the size of the wheel. It will be stamped into a steel wheel or cast into an aluminum wheel.
Paul Gagnon
Dead Link Removed
it's depends apon the rim design ford made 2 different rim sizes in the 16 range for the explorer 16x7 and a three star design 16x7.5 My friend runs 265 70 r16 on his 97 sport 4X4
My 95 Sport has 16x7" wheels. It came stock with 255-70x16 tires. It now "sports" Mickey Thompson 32x11.5/16 Baja Belted tires.
Rick
RickG
95 Explorer Sport Expedition
Hay RickG do your 32s rub? Did you put differt rims on for back-spacing? Or are you running a lift?
Tech1,
The driver's side rubs at full lock on the sway bar. Stock 16x7 chrome rims.
2" lift. Check out General Explorations-"Why No Late Model Lifts?" by Keith on this web site. I've outlined how I did the lift. I'll have a Web Page up as soon as I get the latest Pictures back.
Rick
RickG
Hey ExplorGm, what is a explorer sport expedition?. I have a 95 explorer sport that came with 235/75/15 tires. Do you have a body ift to fit those 32's under it. I've heard that 31/10.50 won't fit under mine. 31/9.50 will. How did you get 32/11.50 under it. Don;t they scrub. I have 30/9.50 now. bridgestone dueler A/T.
The Explorer Sport Expedition is the top of the line sport model . It has such things as 4.10 gears and the bigger v6 . You won't see any badgeing on them referring to this model on the truck but, it does exsist in the shop manuel . Oh and by the way you can easly fit 31.10.50 on your truck I have another friend who has a 2wd sport and he's riding on my old 31's .
Tree what tree
Actually wildman there is Expedition Badging on these. I saw one of these today for the first time. The Expedition name was in the place where you would normally see Sport on the back name plate. I am guessing that the one I saw today was a 96 because it had the urethane fender flares and the round tube running boards and the Expedition became it's own model in '97. Other than the Expedition badge I could not tell any difference from any '97 Sport. But then maybe the running boards and the urethane flares are part of the package because I thought those were only available '97 and up. Ford probably dropped all other variations of the Sport in '97 and kept all the Expedition options on the Sport. Does anyone know for sure?
Paul Gagnon
Dead Link Removed
I have a 91 explorer xlt 4x4 with 265 75 15 tires with no rubbing and better handling than the 235's.
