Explorer Forum Covers the Explorer ST, Explorer Sport, Explorer Sport Trac, Lincoln Aviator,
Mercury Mountaineer, Mazda Navajo, Ford Ranger, Mazda Pickups, and the Ford Aerostar
Register Today It's free!
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an alternative browser.
Completed Project Rock Jock 60 and ladder bar - Pumpkin on the upgrade path...
- Thread starter Rick
- Start date
Use this prefix for completed projects that are not "How to" articles or threads asking for help.
Add an avatar, upload photo attachments, and more!.
- February 8, 1999
- Wayoutin, Aridzona
- '93 XL '20 ST
- Callsign
- AB7FH
Well the bouncing dude in the post above has been going for about 3 extra weeks now. I think I should delete him to give him a rest
The axle was delivered today
turboexplorer
- August 23, 2008
- Eagle Mountain, UT
- 98' XLT 5.0L 4X4
- Callsign
- Turbo
kert0307
- September 6, 2005
- Pella, Iowa
- '00 Sport and '89 B2
If you upgrade in the future to a front d60, are you sure your 15" wheels will clear the brakes? Just something to think about since you sound like you only want to buy tires once...
- February 8, 1999
- '93 XL '20 ST
- Callsign
- AB7FH
- January 14, 2001
- Fresno CA
- 86 ranger no more
- Callsign
- KK6TDL
Are you adding a traction bar?
Diff Whack Daddy
And the Roll Over Posse! Under the Hood Moderator
Moderator Emeritus
- February 19, 1999
- Mount Vernon, WA
- 1st Gen XLT 4dr
- Callsign
- KG7VTT
Yes, there will be a traction bar this time.
I am sure your u-joints will thank you for that.
- February 8, 1999
- '93 XL '20 ST
- Callsign
- AB7FH
Yes, they are some beefy perches. Best of all, they are a bit longer than normal which should also help with spring wrap.
- February 8, 1999
- '93 XL '20 ST
- Callsign
- AB7FH
turboexplorer
- August 23, 2008
- 98' XLT 5.0L 4X4
- Callsign
- Turbo
I assume the shackle is so it can move forward and backwards with the compression and rebound of the spring but not able to move up and down which in turn eliminates or minimizes axle wrap.
Never seen that before.
