rocker panel rust?? | Ford Explorer Forums
rocker panel rust??
new4wheeler
calgary, alberta
92, eddie bauer
i was wondering if there might be a bolt in replacement for the rocker panels i was told there might be some for the 92 explorer, or if anyone has any ideas on how to fix the rust on the rockers would be great, i have so much rust there i may as well not have any rockers at all, lol, any help would be great thanks...
i had the same problem and got it done at a cheap body shop (which was stupid because its rusty again). you could try to bondo it depending on how bad it is, but i haven't heard of a bolt on replacement unless you want to fix a piece of sheet metal to it.
The ONLY way to STOP rust it to cut it all the way out.
Hey man, I had the same problem, actually right at this moment I have all of the new metal for my rocker panels, fender and dog legs. I just got all new metal except for the fender, got it at a junkyard. What I did was put some POR15 , rust preventative, on the backside of the fender where it rusted out, and just cut out and welded in the dog legs and rocker panels. Then I got everything painted and it should look great!! I really hate this Iowa rust crap. hope helps,.
new rocker panels
Dead Link Removed This might help some?
Where can I get the slip on rocker panels for 2010 Ford Explorer
