08TXExplorer
- December 26, 2015
- Texas
- 2008 Ford Explorer
Hello everyone. First time posting. I have a 2008 Explorer with the 4.0 that started throwing the P0401 code. I decided to replace the whole EGR assembly because the sensor and solenoid are all connected. The removal was not too bad (bolts were a bit tough to loosen and there was not much room to loosen the 1 1/16" compression fitting from the manifold). Installation was not too difficult either. I made sure the metal gasket indention was toward the front. There is no longer any code or check engine light. Assuming everything was installed correctly, I am not sure why the truck idles rough (cold and warm). It idles around 650 to 700 rpms. It seems like it is starving for gas or sucking in air. I have checked and rechecked anything that I moved or may have bumped during the EGR replacement. I did a visual inspection for any leaks but did not see any. I am at a loss as to why it idles rough (and has lower performance) after replacing the EGR. Any suggestions? Thanks in advance.
