Pontisteve
- August 30, 2008
- Florida
- 03 Eddie Bauer 4WD V8
First off this has been a great thread and has saved me a heap of cash but here is what I'm experiencing. rough idle, bought cleaner for mass air flow and cleaned it twice, after cleaning the old IAC twice as well I decided to replace it. Replaced the 90 degree rubber elbow as described so it's new. Took the ERG off inspected and it ok but I cleaned it as well. Put new plugs and boots in. Changed air filter. I've run the UNLIT propane around every hose I could find with no motor idle increase at all. I just feel like ice tried everything and all that's left is the MAF to try and replace.
Codes I was getting we're the MAF and IAC. The CEL has come back on and unfortunately it's going to be a week before I can get back and get the MAF installed. Has anyone had any luck with aftermarket MAF units? The original equipment MAF is running $188 and I know that's cheap compared to taking the car to the dealership. Just looking for opinions and experience.
The Motor is in my 02 Eddie Bauer explorer with the 4.6L V8.
Motor ran fine for about 60 miles and now has started to revert back to the issue of a rough idle and while driving it has a tendency to shutter or stall while at speed.
What it also seems to be doing is running very rich at idle and at speed. At idle you can smell the extra fuel coming out the exhaust.
My last ditch effort will be to replace the mass air flow unit and see if that corrects the problem. What my question is does the mass air flow unit really have that large of an affection on the motor at idle? it just baffles me how the motor can go from running so smooth to so rough at both idle and at speed. At highway speeds i would also describe the acceleration as mushy and at other times fine. Very weird.
Any other things I should be looking at besides the Mas air flow unit. How about O2 sensors?
Thanks again
Harry
Again thanks for the insight this thread has provided.
Harry, don't throw parts at this thing. You will be sorely disappointed, and kicking yourself for spending hundreds and not fixing it. If you must throw money at the problem, throw it at paying someone to diagnose your car properly (and that means a GOOD technician, not just any mechanic). Or, spend your money on a good scantool. That's never a waste.
The Ford mass air meters don't fail often, and it's very unlikely to be your problem. If you must guess, try buying a used MAF off Ebay. But I can almost guarantee you it's probably a waste of money. They just don't have a high failure rate. They DO have a high rate of getting dirty. Remove the 2 security torx bits, pull the MAF sensor out of its housing, and spray the crap out of it with MAF cleaner, right on those 2 resistors. If they look dark brown or black and clumpy, they're dirty. Clean, they will look a light color and smooth and visible.
The O2 sensors would be my guess. Does the car run well when cold, and just fine at WOT, but like crap when warm and at idle or part throttle (closed loop)?
What exact codes did you get? Does your scan tool have Freeze Frame data? If so, what RPM and load and throttle position does the freeze frame data show?
