proradvlx
- March 24, 2011
- Indianapolis, IN
- 2004 XLT AWD
Wondering if anyone has come across this in with their vehicle.
First, history: 2004 Explorer XLT 4door AWD 4.0L V6 Flex Fuel
Noticed slight rough idle at or below 1000rpm - above 1000, no problem. Then started getting the "Service Engine Soon" light, and when running the codes would get either " Bank 1 too lean " or " Bank 2 too lean ", or both.
Here's what I've already replaced, in the order replaced:
1. Both upstream/pre-cat oxygen sensors ( Motorcraft parts )
2. Both downstream/post-cat oxygen sensors ( Motorcraft parts )
3. Fuel filter ( Motorcraft part )
4. Mass air flow sensor.
Just did the MAF today - started the engine, started up fine, smooth, then idled down.... and got to about normal idle rpm, started feeling the rough idle. So none of the changes seem to have an effect, and I'm running out of ideas. The only other thing I can think of is the fuel pump....... but it's OK above 1000rpm, and I'm REALLY hoping it's not the fuel pump.
So, any way to check the fuel pump at or below 1000rpm, or any other ideas you could throw at me, I would greatly appreciate it!! Thanks!
