jlrohio
- August 10, 2004
- Virginia
- 1999 Ford Explorer XL
2011 Ford Explorer XLT (45K miles)
- 3.5L V6 TIVCT Cyclone Engine
- Misfire - Cylinder 1
- Codes: P0201, P0301, P0316
Yesterday, I get a call from the wife that her vehicle is running very rough and there's white smoke coming out the back of the vehicle and she smells gasoline. She pulled the vehicle over and I had it towed home.
Today, I was able to get a scanner on it and pulled codes: P0201, P0301, and P0316
P0201 - Injector Circuit / Open Cylinder 1
P0301 - Cylinder 1 misfire detected
P0316 - Misfire detected on startup (first 1000 revolutions)
After scanning the codes, I went to start the vehicle to see how it operated and verified that it was running very rough and yes there was white smoke coming from both tailpipes and the heavy smell of gasoline in the air. While it was running, I was able to put a stethoscope up to all injectors and they all appear to be clicking away. I then turned it off while I then tried to go online and figure out the firing order of the 3.5L V6 TIVCT Cyclone Engine.
I could not find anything definitive for the firing order of this 3.5L engine and was hoping someone could confirm the firing order of this engine? Is this it?
Passenger | Driver
1 2 3
o o o
o o o
4 5 6
Front of Vehicle
I hope the above is NOT the correct firing order, as #1 cylinder would be under the intake manifold!
Another issue crept up here and I'm not even sure it is related or just a major coincidence but when I went to restart the vehicle, it would not start - the battery was dead! I jumped it and got it running but then noticed after a while the battery appeared to be draining itself (watching a multimeter go down) and again was dead. I decided at that point to just go buy another battery and be ready for tomorrow. I figured at 5 years and heading into winter, it was safe insurance to replace the battery.
Can a bad coil or problem spark plug cause battery drain issues, in addition to misfires?
Passenger | Driver
1 2 3
o o o
o o o
4 5 6
Front of Vehicle
