- February 8, 1999
- Wichita KS
- 98 Merc
Rough Idle Questions (Now with Video)
Okay all, I will post a video Tuesday of what this thing is doing. For now I will try to describe it. I have a 1995 4.0 OHV with 187k miles on it. Here is what has been done.
Spark Plugs/Wires
Fuel Filter
Air Filter
EGR Valve
Upper and Lower Manifold Gaskets
IAC
Both 02 sensors
Vacuum is tested to be around 16 which I am told is good here for Colorado.
Fuel Pump
Fuel Filter
TPS
It is still running really rough. I would say it's rompy like up and down real good. I need to get a meter and test the TPS but I figured with 187k on the clock I should probably just replace it. However I have already swapped it with the one off my '93 and still had the same results. I am not sure that one is even good anymore as the motor it came on is gone.
Here is what is left,
MAF
What else?
Thanks!
Spark Plugs/Wires
Fuel Filter
Air Filter
EGR Valve
IAC
Both 02 sensors
Fuel Pump
Fuel Filter
TPS
MAF
What else?
Thanks!
