CZSteve
- November 19, 2005
- Arlington, TX
- '98 Mountaineer
Wife's car is a '98 Mercury Mountaineer 5.0 2WD.
The car began exibiting the 'chirp' coming from the front of the engine.
Appeared to be the drive unit for the cam position sensor.
Based upon a comment here, I decided to try a stop gap by pulling the sensor and spraying white lythium grease down drive unit.
The CMP sensor looked terrble, the magnet was rusty and a bit loose in the plastic housing. I re-assembled everything and upon starting the idle was quite rough.
Figured it was the sensor and a result of my disturbng it when I removed it.
Put a new sensor in from NAPA and the idle is STILL rough.
I've checked the plug connections and everything seems good.
The drive unit was never pulled or rotated, I just removed/replaced the cam position sensor.
BTW the 'chirp' is gone at least (for now)
Any thoughts?
Thanks in advance.
Steve
Any thoughts?
Thanks in advance.
Steve
