rough idle | Ford Explorer Forums
rough idle
blackout93
vancouver,washington
1993,ford,explorer
I have a 93 ex, and recently it has been idling rough when it gets warmed up. its also gutless when its running rough, sometimes it will switch back to normal for a few minutes while driving and then back to running rough.
i have changed the plugs and wires and its still the same. i have no idea whats causing any feed back would be appreciated
thanks!
May have a failing fuel pump. Check fuel pressure under load. Often a cold pump that is failing will put out adequate pressure, but once warmed up it will quickly become unable to supply enough fuel.
Any codes?
Any codes?
oh damn how would i know for sure thats the problem? i dont wanna change the fuel pump unless i have to haha
the check engine light does not come on at all
