D
Dusty T.
Just for kicks I ran some of my truck's numbers through an rpm calculator at: http://www.4lo.com/4LoCalc.htm and http://www.csgnetwork.com/multirpmcalc.html.
Both calculators produced the same numbers for my '91 Ranger. I am running little 27" BFG A/T tires, 3.55 gears, and I'm pretty sure I have the M50D-R1 5-speed manual bolted to the 4.0L (which has a .79 ratio in 5th according to http://www.rangerpowersports.com/tech/?p=71). What I'm uncertain of is the RPM's calculated seem to be on the low side compared to what my tach actually reads.
For example, the calculator shows:
60- 2094 RPM
65- 2269 RPM
70- 2443 RPM
75- 2618 RPM
80- 2792 RPM
85- 2967 RPM
My tach shows:
60- ~2000 RPM
65- ~2300 RPM
70- ~2500 RPM
75- ~2800 RPM
80- ~2950 RPM
85- ~3100 RPM
So I'm wondering if the tach in my truck is not very accurate? I have heard that they aren't It seems like the RPM calculator gives lower numbers than what my tach shows and how the engine sounds. It also seems like the tach shows very little engine speed difference between 78 and 85 MPH, but RPM should increase constantly according to speed, right?
Thanks for any input. My apologies if this topic has been beaten to death.
60- 2094 RPM
65- 2269 RPM
70- 2443 RPM
75- 2618 RPM
80- 2792 RPM
85- 2967 RPM
My tach shows:
60- ~2000 RPM
65- ~2300 RPM
70- ~2500 RPM
75- ~2800 RPM
80- ~2950 RPM
85- ~3100 RPM
