double_u_4
- June 13, 2012
- romeoville,il
- 2000 Ford Explorer
well i just got my truck back after having timing replaced. & the truck was running good for a few mins. but it started to run rough & chug. the exhaust was turning cherry red,it had a misfire. so we put in new plugs, wires,coil pack, crank sensor, & that seemed to work for about a day then it started to run rough again. if i am @ highway speeds just coasting its fine. but under any acceleration it chugs hard & seems like it doesnt want to go. i checked to make sure the wires were to the correct plug That checked out fine. it almost feels like wires are switched to the wrong plug but they arent. but now im getting a 0420 code. there is a small leak in the exhaust after the cat. it looks like the gasket isnt in all the way & about the last ft on the tail pipe has a bend in it. would those 2 things with the exhaust cause that big of a problem & make the truck run rough like that. the bend in the tail pipe has been there since i got the truck last year so i dont think that would make any difference,
