sas in my future couple of ??? | Ford Explorer Forums
gluvsave35
Long Island NY
1997 xlt v8
so this summer i will probably be doin a sas on my truck!!:) yah 4 me
i will be using a ford 9" in the back and a dana 44 up front.. dont know wut gears yet but i got some time to figure that out
i want to run 37's
my ??? is if i put manual lockin hubs up front does this make my awd truck a 2 wheel drive truck until i lock those hubs....
and also has anybody made there rear a posi????(an sas'd truck not a street truck)
______________________________________________________
also way off topic hear wut is a trans brake and how does it work...
wouldnt a line break be better
(was watching pinks! (im not think of puttin one in my truck i just want to know!!!!:))
If i can tell you anything for doing my own sas is to spend time reading in the sas threads and spending time in the many diffrent sas threads.....There is a wealth of info here....It will be to your advantage to read up....I spent a long time reading and i wish i had spent more time.....
If you wanna run 37's you want 5.13's;)
Yes research research research. Spend a month (at least) just reading and understanding the main concepts. Don't always follow what other people have done. If you see better ways of doing something, then go for it -- as long as you understand the main concepts and know the limitations of the materials your working with, then you should be good to go.
i want to run 37's
If you want 37's with that v8 you will probably want 4.88's, and you will need to change your AWD t-case to a selectable t-case 2wd 4hi/4lo most likley from a first gen.
Yes, manual locking hubs make it 2wd untill you lock them and engage the t-case.
And dont call it a posi, posi's are for chevys. If you mean a locker/limited slip, yes, everyone and their mother has a locker. Ive got a full spool, other have selectable lockers or lunchbox lockers (search)
